PC Home build
Asus A8N 32 sli deluxe
Bios AMI 64-1009
Chipset nF4-sli
AMD 3.5+ (2.20ghz)
Corsair twinx 1024-3200 DDR400mhz SDRAM 2x512mb
MSI 6600gt 128 PCI-E
Maxtor sata 160mb
PSU 400w
XP sp2
X45
I am trying to learn a little how my mobo, CPU, Chipset etc worrk & interact between them.
I went as far as this O/clock 2.4ghz, from the standard 2.2ghz, and no matter what combination of changes I try to change it becomes unstable and cannot improve it.
These are the actual Bios settings I entered:
FSB=240, CpuMultplr=10, Vcore=1.3625, Hyprtr Mulplr=4x, VRam=2.60 Ram Divdr 166
RAM divider = [166]
Vcore = 1.425v (true Vcore as measured in Speedfan)
HTT = 240mhz
CPU multi = 10x
RAM = 200mhz
HT multi = 4x
I use "Stress Prime" on every change of settings, and monitor Ts constantly.
Resulted Temps are :-
Temps STATIC: Cpu 29c, Chipset 34, 30c, 29c, 33c.
Temps with fs9 over LHR: CPU 39c, Chipset 36c, remote 54c, Local 41 & HD 34
The phraseology of the different terms used fo O/clocking varies from one write up to another. It is very confusing.
I find difficulty in understanding if MEMCLOCK is same as Memlock Value ( or RAM DEvider perhaps ?),
What is DDR & where is used.
What & where is Ram Speed? or "RAM" & "RAM Base Speed" ?
One time I read of Standard Ram speed 400mhz, the next 200mhz
Is there a LIST for which value is used to O/Clock what, just the names.
i.e. for:
A. CPU - FSB, It's Multiplier, VCore ?...........etc
B. MEMORY - VRAM, MemClock ?..................etc
C. MOBO - ?
D. GRFX - ?
D. CHIPSET - ?
Why when I used FSB 240, on bootup it posted "DRAM Clocking 333", and with FSB 220 posted "Dram clocking 400" etc ?
PS. Is there a way of posting here the IMG below?
Bios AMI 64-1009
Chipset nF4-sli
AMD 3.5+ (2.20ghz)
Maxtor sata 160mb
PSU 400w
XP sp2
X45
RAM divider = [166]
HTT = 240mhz
CPU multi = 10x
RAM = 200mhz
HT multi = 4x
i.e. for:
C. MOBO - ?
D. GRFX - ?
D. CHIPSET - ?
