Mugglensu1984 :
Christian Vilderman :
Saif Uv :
Im not an expert of CPUs or anything though.
We are talking about 5960X an 8 core processor with 16 threads built on efficient Haswell architecture almost already pushed far enough (Im not talking about the frequency). Considerably best mainstream processor (Experts: correct me if im wrong) available Idk if Xeon 18 core is mainstream or not.
You think that 3.0 Ghz is too low ?
Please notice that frequency doesnt matter that much in new intel processors.
I`d say you should only OC your processor if
1) its lagging
2) its old and you just want to see whats the limit of the chip and have no problem with frying it because you`re going to get a new one soon.
Drawbacks of OCing
1) You may fry your dear chip
2) You definitely are decreasing the life span of your chip.
3) Instability etc
4) CPU running at high temps . ( You must want to keep it cool ).
You certainly dont want that with your processor you bought for 1k.
And YES OCing 5960x is pointless for a 3D artist considering that even AMD FX series with 6-8 cores do well in rendering and 3D stuff ( correct me if im wrong experts) .
And single core performance of this chip must be twice as AMD FX processors.
Thanks. I think you have mentioned some good points.
I am going to go back to stock speed. The main reason being is that I am finding it not that stable at 4.4 ghz. I am getting a few crashes on applications and freezes. I moved from Mac to Windows so I dont know if Windows always does this? When you buy a £900 cpu you dont expect any major issues. I will report back with how the stock speed 5960X is vs the OC (in terms of user experience and not benchmarks etc).
Thanks
The rashes and freezes are due to inadequate voltage to the cpu. Increase the voltage with 0.025 increments and you will see these problems vanish.
Hi Mugglensu1984.
I have take your advice and tweaked the voltage from 1.280 to 1.295.
I am now doing some heavy cinema 4d rendering to test stabiltiy etc and everything seems good. temps are bouncing around from 70-86. It does drop down to 50 degrees between frames. When idle I am getting around 40 which is good. I must say that upping the voltage really does seem to eliminate my "rashes and freezes" etc. So I think I owe you a massive thank you on that one.
Here are my specs:
5960x cpu
Motherboard | RAMPAGE V EXTREME
titan x gpu
32gb ripjaw ram
loads of hhds and ssds.
Corsair Hydro Series H100i
Corsair 850m 850W psu
Corsair Obsidian Series 750D ATX Full Tower
here is also HW monitor text file if that can tell you anything.
CPUID HWMonitor Report
Binaries
HWMonitor version 1.2.7.0
Monitoring
Mainboard Model RAMPAGE V EXTREME (0x000004AD - 0xEA574CD0)
LPCIO
LPCIO Vendor Nuvoton
LPCIO Model NCT6791
LPCIO Vendor ID 0x5CA3
LPCIO Chip ID 0xC8
LPCIO Revision ID 0x3
Config Mode I/O address 0x2E
Config Mode LDN 0xB
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 FF FF 00 FF FF FF FF 0B FF FF FF FF FF FF FF FF
10 FF FF FF 00 00 FF FF FF FF FF 0A 26 00 00 FF FF
20 C8 03 FF 00 00 00 10 00 00 FF 40 00 00 02 00 03
30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 02 90 00 00 0A 00 FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Register space LPC, base address = 0x0290
Register space class = 0x8, base address = 0x0A00
Hardware Monitors
Hardware monitor Nuvoton NCT6791
Voltage 0 0.93 Volts [0x74] (CPU VCORE)
Voltage 1 1.01 Volts [0x7E] (VIN1)
Voltage 2 3.33 Volts [0xD0] (AVCC)
Voltage 3 3.33 Volts [0xD0] (3VCC)
Voltage 4 1.00 Volts [0x7D] (VIN4)
Voltage 5 1.94 Volts [0xF2] (VIN5)
Voltage 6 0.66 Volts [0x52] (VIN6)
Voltage 7 0.28 Volts [0x23] (VIN7)
Voltage 8 0.93 Volts [0x74] (VIN8)
Voltage 9 0.66 Volts [0x52] (VIN9)
Voltage 10 1.00 Volts [0x7D] (VIN10)
Voltage 11 1.01 Volts [0x7E] (VIN11)
Temperature 0 32°C (89°F) [0x20] (SYSTIN)
Temperature 1 51°C (123°F) [0x66] (CPUTIN)
Temperature 3 83°C (181°F) [0x53] (TMPIN3)
Fan 1 2299 RPM [0x8FB] (CPUFANIN)
Fan 2 1111 RPM [0x457] (AUXFANIN0)
Hardware registers
bank 0
00 04 FF 04 FF 00 FF FF FF FF FF FF FF FF FF FF FF
10 04 FF 04 FF 04 FF 03 FF 40 85 23 67 52 52 52 00
20 74 7E D0 D0 7D F3 52 20 FF FF FF DA 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF
40 03 1E 07 FF DF 10 1E FF 2D FF FF 10 00 55 00 A3
50 05 FF FF FF FF FF FF FF C1 FF FF FF FF 01 00 FF
60 AA 0C FF FF FF 01 00 FF FF FF FF FF FF FF FF FF
70 00 0A 00 47 80 48 80 47 80 47 80 23 00 FF FF FF
80 FF 7F 3F BF FF 05 05 05 00 00 00 00 00 00 00 00
90 0A 00 00 00 00 FD FD FD 0A 95 EF 80 FF 40 46 C4
A0 0E FF 00 00 FF 00 00 FF 00 00 80 66 06 06 01 00
B0 00 00 00 00 00 00 2F 00 04 00 00 34 28 80 04 00
C0 FF FF FF FF FF FF FF FF FF 0B 07 05 FF FF FF FF
D0 05 05 05 05 00 00 00 00 00 00 00 00 FD FD FD FD
E0 55 80 00 00 00 FF FF FF FF FF 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 84 FF FF FF
bank 1
80 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
bank 2
bank 3
bank 4
80 74 7E D0 D0 7D F3 52 D6 D1 85 23 67 52 52 52 00
bank 5
bank 6
bank 7
Hardware monitor Nuvoton NCT6791D
Voltage 0 5.04 Volts [0x7E] (+5V)
Voltage 1 3.33 Volts [0xD0] (+3.3V)
Voltage 2 12.00 Volts [0x7D] (+12V)
Voltage 3 0.82 Volts [0x67] (VIN3)
Voltage 4 1.31 Volts [0x52] (VIN4)
Voltage 5 1.86 Volts [0x74] (VCORE)
Temperature 0 32°C (89°F) [0x20] (Mainboard)
Temperature 1 82°C (179°F) [0x52] (CPU)
Fan 1 1111 RPM [0x457] (Chassis #2)
00 74 7E D0 D0 7D F3 52 D6 D1 85 23 67 52 52 52 00
10 20 33 2E 64 24 2E 00 2F 80 47 48 47 47 23 2E 0F
20 20 02 FF FF FF FF 00 00 00 00 00 00 00 00 FF 1F
30 12 1F 25 1F FF 1F FF 1F FF 1F 00 00 08 FB 04 57
40 00 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF
50 FF FF 52 C0 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 48 00 F5 00 FF FF FF FF FF FF FF FF FF FF FF
90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor NVIDIA NVAPI
Voltage 0 1.02 Volts [0x400] (VIN0)
Temperature 0 63°C (145°F) [0x3F] (TMPIN0)
Fan 0 1112 RPM [0x458] (FANIN0)
Fan PWM 0 23 pc [0x17] (FANPWMIN0)
Processors
Number of processors 1
Number of threads 16
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Thread 1 1
-- Core 1
-- Thread 0 2
-- Thread 1 3
-- Core 2
-- Thread 0 4
-- Thread 1 5
-- Core 3
-- Thread 0 6
-- Thread 1 7
-- Core 4
-- Thread 0 8
-- Thread 1 9
-- Core 5
-- Thread 0 10
-- Thread 1 11
-- Core 6
-- Thread 0 12
-- Thread 1 13
-- Core 7
-- Thread 0 14
-- Thread 1 15
Timers
ACPI timer 3.580 MHz
HPET timer 14.318 MHz
Perf timer 2.935 MHz
Sys timer 1.000 KHz
Processors Information
Processor 1 ID = 0
Number of cores 8 (max 8)
Number of threads 16 (max 16)
Name Intel Core i7 5960X
Codename Haswell-E/EP
Specification Intel(R) Core(TM) i7-5960X CPU @ 3.00GHz
Package (platform ID) Socket 2011 LGA (0x2)
CPUID 6.F.2
Extended CPUID 6.3F
Core Stepping M0
Technology 22 nm
TDP Limit 140.0 Watts
Tjmax 105.0 °C
Core Speed 4406.8 MHz
Multiplier x Bus Speed 44.0 x 100.2 MHz
Stock frequency 3000 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA3
L1 Data cache 8 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 8 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 8 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 20 MBytes, 20-way set associative, 64-byte line size
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 30x
Max turbo ratio 33x
Max efficiency ratio 12x
Min Power 49 Watts
O/C bins unlimited
Ratio 1 core 44x
Ratio 2 cores 44x
Ratio 3 cores 44x
Ratio 4 cores 44x
Ratio 5 cores 44x
Ratio 6 cores 44x
Ratio 7 cores 44x
Ratio 8 cores 44x
Ratio 9 cores 33x
Ratio 10 cores 33x
Ratio 11 cores 33x
Ratio 12 cores 33x
Ratio 13 cores 33x
Ratio 14 cores 33x
Ratio 15 cores 33x
Ratio 16 cores 33x
Ratio 17 cores 33x
Ratio 18 cores 33x
TSC 3005.4 MHz
APERF 4407.7 MHz
MPERF 3005.4 MHz
IA Voltage Mode Override
IA Voltage Target 1326 mV
IA Voltage Offset 0 mV
GT Voltage Mode PCU adaptive
GT Voltage Offset 0 mV
LLC/Ring Voltage Mode PCU adaptive
LLC/Ring Voltage Offset 0 mV
Agent Voltage Mode PCU adaptive
Agent Voltage Offset 0 mV
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01020202h
Max CPUID level 0000000Fh
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 32 KB, 2 thread(s)
Cache descriptor Level 2, U, 256 KB, 2 thread(s)
Cache descriptor Level 3, U, 20 MB, 16 thread(s)
CPUID
0x00000000 0x0000000F 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x000306F2 0x00100800 0x7FFEFBBF 0xBFEBFBFF
0x00000002 0x76036301 0x00F0B5FF 0x00000000 0x00C10000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x1C004121 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004122 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004143 0x01C0003F 0x000001FF 0x00000000
0x00000004 0x1C03C163 0x04C0003F 0x00003FFF 0x00000006
0x00000005 0x00000040 0x00000040 0x00000003 0x00002120
0x00000006 0x00000077 0x00000002 0x00000009 0x00000000
0x00000007 0x00000000 0x000037AB 0x00000000 0x00000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000001 0x00000000 0x00000000 0x00000000
0x0000000A 0x07300403 0x00000000 0x00000000 0x00000603
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000000
0x0000000B 0x00000004 0x00000010 0x00000201 0x00000000
0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000007 0x00000340 0x00000340 0x00000000
0x0000000E 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000F 0x00000000 0x0000001F 0x00000000 0x00000002
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000021 0x2C100800
0x80000002 0x65746E49 0x2952286C 0x726F4320 0x4D542865
0x80000003 0x37692029 0x3639352D 0x43205830 0x40205550
0x80000004 0x302E3320 0x7A484730 0x00000000 0x00000000
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x01006040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000100
0x80000008 0x0000302E 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0x0000003A 0x00000000 0x00000001
MSR 0x000001A0 0x00000000 0x00850089
MSR 0x000000CE 0x00080C3B 0xF3811E00
MSR 0x00000017 0x00080000 0x00000000
MSR 0x00000035 0x00000000 0x00080010
MSR 0x000000C1 0x00000000 0x00000000
MSR 0x000000C2 0x00000000 0x00000000
MSR 0x000000C3 0x00000000 0x00000000
MSR 0x000000C4 0x00000000 0x00000000
MSR 0x00000186 0x00000000 0x00000000
MSR 0x00000187 0x00000000 0x00000000
MSR 0x000001AD 0x2C2C2C2C 0x2C2C2C2C
MSR 0x000001AE 0x21212121 0x21212121
MSR 0x000001AF 0x00000000 0x00002121
MSR 0x00000194 0x00000000 0x000E0000
MSR 0x0000019A 0x00000000 0x00000000
MSR 0x000001A4 0x00000000 0x00000000
MSR 0x000001B1 0x00000000 0x88160000
MSR 0x000001FC 0x00000000 0x2B040059
MSR 0x00000606 0x00000000 0x000A0E03
MSR 0x00000601 0x00101414 0x00001FFF
MSR 0x00000610 0x0007FFF8 0x0015FFF8
MSR 0x00000611 0x00000000 0x4A1C8176
MSR 0x00000639 0x00000000 0x00000000
MSR 0x00000619 0x00000000 0x02EA2D07
MSR 0x00000614 0x00000000 0x01880460
MSR 0x0000019C 0x00000000 0x881E0000
MSR 0x000001A2 0x00000000 0x00691200
MSR 0x00000198 0x00002981 0x00002C00
MSR 0x00000199 0x00000000 0x0000FF00
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 0, Thread ID 1
Type 01020202h
CPUID
0x00000001 0x000306F2 0x01100800 0x7FFEFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000001
0x0000000B 0x00000004 0x00000010 0x00000201 0x00000001
MSR 0x0000001B 0x00000000 0xFEE00800
MSR 0x00000611 0x00000000 0x4A1E12DE
MSR 0x00000619 0x00000000 0x02EA38F7
CPU Thread 2
APIC ID 2
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 01020202h
CPUID
0x00000001 0x000306F2 0x02100800 0x7FFEFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000002
0x0000000B 0x00000004 0x00000010 0x00000201 0x00000002
MSR 0x00000611 0x00000000 0x4A1FA4D1
MSR 0x00000619 0x00000000 0x02EA4507
MSR 0x0000019C 0x00000000 0x88220000
