Question Help on picking parts for new PC
holdithoncho
14
Approximate Purchase Date: This week
Budget Range: 2500 euro
System Usage from Most to Least Important: 4k gaming mostly
Are you buying a monitor: No
Parts to Upgrade: new build
Do you need to buy OS:
No
Please note that if you're using an OEM license of Windows, you will need a new one when buying a new motherboard.
Preferred Website(s) for Parts:
amazon.de or caseking
Parts Preferences:n/a
Overclocking:
Maybe
Your Monitor Resolution: 2560x1440(will be upgrading monitor later in the year)
Additional Comments:
(not that pushed on looks or noise level. Would prefer reliable performance on games like cyberpunk/Elden ring
And Most Importantly, Why Are You Upgrading: selling an old pc to a friend and need a new one.
https://www.amazon.de/-/en/Fractal-Design-Focus-White-Clear/dp/B08Z4F5Q65/
Fractal Design Focus 2 RGB ATX Mid Tower Case €94.66
https://www.amazon.de/-/en/Arctic-P12-PWM-Optimized-Pressure/dp/B07GB5JRTZ/
Arctic P12 PWM 120mm 4-Pin Case Fan €5.99
MSI MPG A850G PCIE5 850W 80+ Gold Modular ATX Power Supply €138.90
ASUS TUF GAMING H770-PRO WIFI €214.24
Intel Core i7-13700F €399.00
DeepCool AK620 Dual Tower CPU Cooler €69.99
https://www.amazon.de/-/en/G-Skill-F5-6000J3238F16GX2-FX5-Memory-Module-6000MHz/dp/B0BFG9VTKL/
G.Skill Flare X5 DDR5 6000 32GB (2x16GB) CL32 €128.33
https://www.amazon.de/Samsung-MZ-V7S2T0BW-Plus-Internal-3-500/dp/B07MLJD32L/
Samsung 970 Evo Plus 2TB M.2 PCIe 3.0 x4 NVME SSD €113.99
https://www.amazon.de/-/en/Sapphire-Pulse-Radeon-7900-GDDR6/dp/B0BQNCSW3X/
Sapphire Pulse Radeon RX 7900 XTX 24GB Video Card €1,069.00
Total: €2234.20
A better look at those components.
https://www.fractal-design.com/products/cases/focus/focus-2/rgb-white-tg-clear-tint/
https://www.asus.com/motherboards-components/motherboards/tuf-gaming/tuf-gaming-h770-pro-wifi/
Reactions: Lucky_SLS
Total: €2234.20
Thanks for the parts list looks really good. Would it be worth spending the extra few quid to get maybe a ryzen 7 7800X3D or is that just a bit overkill?
It's a bit of a risk tm.
Considering the prices from the and parts availability from the specified merchant I would make the build like this:
PCPartPicker Part List
CPU: AMD Ryzen 7 7700X 4.5 GHz 8-Core Processor (€343.90 @ Amazon Deutschland)
CPU Cooler: Thermalright Phantom Spirit 120 SE 66.17 CFM CPU Cooler (€45.90 @ Amazon Deutschland)
Motherboard: Asus TUF GAMING B650-PLUS WIFI ATX AM5 Motherboard (€208.20 @ Amazon Deutschland)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory (€116.24 @ Amazon Deutschland)
Storage: Crucial P5 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (€139.99 @ Amazon Deutschland)
Video Card: Palit GamingPro GeForce RTX 4080 16 GB Video Card (€1189.00 @ Amazon Deutschland)
Case: Fractal Design Pop Air ATX Mid Tower Case (€90.83 @ Amazon Deutschland)
Power Supply: SeaSonic FOCUS 850 W 80+ Gold Certified Semi-modular ATX Power Supply (€127.77 @ Amazon Deutschland)
Total: €2261.83
Generated by PCPartPicker 2023-05-09 20:28 CEST+0200
