Help on power needs
josshhh
31
o/ running 2 cards from ATI and Nvidia :p so a psu calculator wont work
Dont troll saying you cant as my new mobo can
http://uk.msi.com/product/mb/870A-Fuzion-Power-Edition.html read the part on fuzion power
Rig overview
that mobo
955 Overclocked core unlocked 4ghz 1.45 vcore
6870
8800GTS 512mb
4gb ddr3 dual channel
7 case fans
XFX 650w XXX Edition Modular PSU (Re branded Seasonic)
Any help on subject would be very nice thanks :)
Thanks
Regards
Josh
This is fairly imprecise but how else are you going to know how much power you will need?
125W CPU + 130W GPU + 150W GPU = 405W.
I couldn't find any details about the TDP of 8800 GTS 512's, so based on the fact that they only have one 6-pin PCIe connector, the card uses between 75 and 150W, so I used 150W as a worst case.
As a worst case, 405W is not going to be stressful to a good 650W PSU. So I don't think you'll have any problems or need to change PSU.
Not bad.
149 watts running Furmark;
http://ht4u.net/reviews/2009/leistungsaufnahme_graka/index13.php
dalmvern
673
What Silvune said.
It is recommended to leave plenty of overhead room with your power for power spikes and upgrades down the line, but as of now a 650W PSU should easily handle what you have.
