HELP ON REBOOT
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
pent 4 3.2 2gig h/d
Had to reinstall xp
got over lots of drive problems
service pack 2 loaded ok
all seems to be fine ran checkdisk ok.
computer sems to work fine
Problem is on restart it seems to take a while and a white bar comes up on
the bottom of screen it slowly fills up I think its a hard drive check but im
not sure.
looks like a set of white bars that fill up
how do i stop this on switch on /reboot it takes ages
many thanks
"bluehawk" <bluehawk@discussions.microsoft.com> wrote in message
news:07BC0BFF-6DEE-4F75-80DE-E4F025A59D49@microsoft.com...
> pent 4 3.2 2gig h/d
> Had to reinstall xp
> im
> not sure.
> many thanks
If you installed Windows XP on a 2 GB Hard drive, it's a wonder it will boot
at all.
A Clean install of Windows XP can take from 1 to 1.5 GB, then add a swap
file, a sizeable piece of space for system restore, and a piece of HDD equal
to installed RAM for Hibernation.
2GB is simply not enough for Windows XP. Minimum drive size should be 10GB.
Bobby
SORRY i meant 200g
any ideas?
> > pent 4 3.2 2gig h/d
> > Had to reinstall xp
> > im
> > not sure.
> > many thanks
> at all.
> Bobby
NoNo:
Although you and I both disagree with Microsoft's assessment, the official
Microsoft minimum requirement for Windows XP is: 1.5 gigabytes (GB)
of available hard disk space*
Read all about it here:
http://www.microsoft.com/windowsxp/pro/evaluation/sysreqs.mspx
steve
"NoNoBadDog!" <no_@spam_verizon.net> wrote in message
news:%23vZPLUTsFHA.3852@TK2MSFTNGP15.phx.gbl...
>> pent 4 3.2 2gig h/d
>> Had to reinstall xp
>> on
>> but im
>> not sure.
>> many thanks
> boot at all.
> equal to installed RAM for Hibernation.
> 10GB.
> Bobby
Bluehawk,
Try this,
How to disable 'Windows File Protection' (WFP)
-open Regedit
-navigate to:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
- double-click REG_DWORD key 'SFCDisable'
-check 'Hexidecimal' > type FFFFFF9D, click OK
-Exit Regedit
Drew
> pent 4 3.2 2gig h/d
> Had to reinstall xp
> im
> not sure.
> many thanks
Drew
Thanks I tried that but its still the same should i change regedit back?
It seems on start up the hard drive is moving around the same as if its
being reformated it seems to be checking itself on start up.
The screen is fully black with white lines at base that fill up during this
time (before windows starts)
once its on the computer works fine and no errors come up
any ideas
many thanks
"Drew Tognola" wrote:
> Bluehawk,
> Try this,
> -open Regedit
> -navigate to:
> -Exit Regedit
> Drew
> > pent 4 3.2 2gig h/d
> > Had to reinstall xp
> > im
> > not sure.
> > many thanks
