I'm building my first gaming PC and I'm having a hard time deciding between the i5-2500K and the i5-3450. The i5-2500K costs $20 more, but is slightly faster and provides overclocking ability. If I go with the i5-2500K, however, I lose the ability to use PCIe 3.0.
Also, if I go with the i5-2500K, the motherboard PCIe 2.0 port is x16 (@x16). The i5-3540 motherboard PCIe 2.0 port is x16 (@x4). Is there a significant difference between @x16 and @x4?
Motherboard for the i5-2500K:
GIGABYTE GA-Z68AP-D3(R2.0) LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard ($79)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128538
Motherboard for the i5-3450:
BIOSTAR TZ77B LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard ($79)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138352
For reference, my GPU is:
Radeon HD 6950 ($208)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150549
