[SOLVED] Help: One of my GPU power pin is bent upward a little bit. Will this affect my GPU in anyway? Thank you in advance.
okjak808
194
26
4,640
7
It won’t effect the GPU in any way, unless it’s getting loose. Make sure to plug in your PCIE cables carefully and don’t wiggle it aggressively when taking it out.
you could to bending it back to its regular form though I would be very careful.
more so if the GPU works fine then no need to worry.
Reactions: Yakibu
okjak808
194
26
4,640
7
Reactions: Yakibu
