[SOLVED] Help opening side panel of PC case. CoolerMaster 5 or Maker 5? Unsure(?) Picture included.
Wheaten
Commendable
Nov 27, 2019
33
Hi,
I'm unsure on how to open the side panel of my PC case, I'm unsure what the case is exactly called and the glass panel but this is the closest thing I could find;
View: https://imgur.com/a/OY0hRM4
https://www.coolermaster.com/catalo...6-mc500-mc600-h500p-and-h500m/#specifications
It says I can use a coin, but the circle lock thing continues to rotate round and round.
Any help is appreciated, thank you.
Case = CoolerMaster Pro 5 or Maker 5 (Not sure which one)
Tempered Glass = MCA-M500R-TGSP00-LGT (I think)
Hi,
It would seem to be a CoolerMaster MasterCase H500P and the manual...
Hi,
It would seem to be a CoolerMaster MasterCase H500P and the manual:
https://www.coolermaster.com/catalog/cases/mid-tower/mastercase-h500p-mesh-argb/#image-Item3
https://coolermaster.egnyte.com/dl/AjJlx5Rb0Z
seems to indicate that you turn the screw clockwise to release the glass panel. Most likely you would only need to turn it 90 degrees but if you still have a problem you should contact their support people on their support page.
