clarkjd :
Gasper Torner :
hi everyone so i have a problem with my graphics card sapphire hd 7770 ghz edition single fan 1gb gddr5 (http://www.sapphiretech.com/productdetial.asp?pid=E526513F-4894-495A-8859-972F2F488D42A&lang=eng) and the problem is that no mather what os or pc you plug it into as soon as the drivers get installed it blackscreens so far i tried some old drivers no luck win 7 and 10 no luck booting into safe mode removing the drivers and booting without internet works fine but no driver connecting my display to onboard graphics and installing the drivers resoult in a blue screen and thats it for now anybody know a solution other than buying a new graphics card becouse they are just so damn expensive these days thanks
Complete system specs would be helpful. Do you have your monitor plugged into your video card or the motherboard?
as is said the graphics card reacts same in every system it was in so system specs not that importand and ofcourse i have my monitors connected to a video card but anyway here is my complete specs just so i don't look rude couse i don't want to be
cpu intel core i3 3220
ram 4gb ddr3
motherboard MSI MS-7788 H61M-P31(G3)
graphics card
storage 2x1tb hdd
os dual boot windows 10 64bit and 7 32bit
graphics card is a sapphire amd radeon hd 6450
the broken one is that sapphire hd 7770 ghz edidtion
and an untested yet asus directcu II Radeon R9 270X still waiting for more six pinners and a bigger case
