Hi!
I have AMD X4 9950 BE in a MSI K9A2 (AMD790FX) and 2 sticks of 1GB RAM @ 667 MHz.
Now the CPU is running at stock clock, that is @ 2.6 GHz.
I have tried to overclock the CPU to 3.04 GHz, but the system gets unstable, it freezes sometimes at Windows logo, sometimes when an app is running, whenever the CPU wants. But I don't think 3.04 GHz is enough, so lets talk about 3.4 GHz! Here are the settings I tried with 3.04 GHz:
FSB clock: 210 (from 200)
CPU multiplier: x14.5 (from x13)
VID: 1.317V (from 1.3V)
Memory Voltage: 1.80V (from 1.75V ?)
increases the memory clock: 700 MHz (from 667 MHz)
- The system is unstable, it sometime is able to boot, but usually freezes. Thought that memory didn't get enough power, but it wasn't it.
Here are the settings I tried with 3.4 GHz:
FSB clock: 200
CPU multiplier: x16.5
VID: 1.371V, 1.400V
- The system was able to boot only a few times, wasn't even able to get in Windows. The temperature was from 30oC to 45oC so I turned up my Zalman.
So what should I try to clock?
Btw, does clocking the HT helps?
FSB clock: 200
VID: 1.371V, 1.400V
