Ok yet another noob overclocking help request. I think I have the basics down but I wanted to get some settings that would push my E8400 as far as it would go with standard intel cooling.
From what I have gathered so far I need to disable all the speedstep stuff. Got that ok.
I know how to increase the FSB speed and set the timings manually. Got that.
I know you have to set the PCI-E freq clock to 100mhz with PCI clock synch to 33.33mhz manually to keep the freq from getting too high when you up the FSB.
The tutorial I saw here as a sticky used the Asus Phoenix BIOS as an example instead of the Gigabyte Award BIOS which I have. They are similar in settings but different in many as well. Seems the Award has many more auto and turbo type settings from my old Asus board.
I don't get how to set the FSB/DRAM speed ratio on the board. I am running a 3.0GHz E8400 with Corsair XMS DDR2 mem rated at PC1066. From what I read for my memory the ratio should be 5:8.
Can anyone give me the settings for this BIOS to push it as far as it will go with stock cooling? I plan on getting a cooler later but my system is brand new.
Help with initial settings please?
