Hi, i have a problem with ibt
I outride ibt test with 4.5Ghz, but with 4.6 crash, Look:
Case:Cooler Master HAF X
Alimentatore:Cooler Master Silent Pro Hybrid 850W 80Plus Gold
Ram:G.Skill Ripjaws-X 2133MHz 8GB CL 9-11-10-28-2N
HDD: Digital Caviar Blue 1TB
MOBO: Asus Maximus V Extreme
CPU: i7-3770K
VGA: Zotac NVIDIA GeForce GTX 670 AMP
Cooling:
Waterblock: EK Water Blocks EK-Supremacy Plexy-Nikel
Pompa: Laing d 5
Radiatore: COOLGATE CG-360HD
the configuration of matherboard for overclock is:
Ai overclock tune Manual
Internal PLL Enable
Xtreme Tweaking Enable
Cpu voltage 1.265
Cpu pll 1.7
vttdr 0.8
Cpu spread spectrum Disable
1 Core ratio 45x
C1e disable
C3 disable
C6 disable
C-state disable
Maximus teak mode1
LLC ultrahigh
Cpu power duty extreme
Cpu current 150%
Dram current 130%
Dram power phase extreme
Dram frequency 2133
Hynix Loose
Vccsa 0.98
Vccio 1.1
Timing 10-12-11-32-2
CPU: i7-3770K
Cooling:
Pompa: Laing d 5
Internal PLL Enable
Cpu voltage 1.265
Cpu pll 1.7
vttdr 0.8
1 Core ratio 45x
C1e disable
C3 disable
C6 disable
C-state disable
Maximus teak mode1
LLC ultrahigh
Cpu current 150%
Dram current 130%
Dram frequency 2133
Hynix Loose
Vccsa 0.98
Vccio 1.1
