Help overclocking Intel P4 2.6Ghz Northwood (478)
GSD
47
Hi all.
I've decided to try and OC my old rig (Intel P4 2.6Ghz Northwood S478/ Asus P4P800SE / 1GB (2X512MB) Corsair XMS3200XL (2-2-2-5).
I am very new to overclocking and need some help. I have the XP-90 CPU cooler which is keeping temps ~ 30C idle and around 36-39C full load using Prime95.
The thing I am confused about is the RAM frequency.
Here is what I've done so far;
Gone into BIOS and slowly increase FSB to 240MHz (currently running stable @ 3.1GHz).
I opened CPU-Z to find the memory running at 160MHz - why is this?
Shouldn't it be running at 240MHz?
Will my RAM go to 240MHz OK?
Screenshots;
Any help would be appreciated.
Quick update;
I just ran a torture test with Prime95 and it failed very quick @ 240MHz. 🙁
Will it help if I increase the CPU voltage? What is a safe voltage to use with this CPU?
The reason for failure could be a RAM not a CPU.
You didnt attach an SPD screen of CPUz which will show Your memory timing.
Maybe at 160MHz is CL2 too tight for them.
