help overclocking MSI A55M-P33
Bob Hennessey
I see in bios where I can overclock but have no idea what exactly to do anyone out there that can give me a step by step process as to what changes I make . Thanks
Thanks for response. It is AMD A4 3400 2.7 ghz 1.0 MB Total Cache. MSI used to send out a manual with their new boards now all you get is a sheet of paper on how to insert ram drives etc. No manual on the driver disk either.
i think since that apu has a locked multiplier that it should be able to overclock pretty much the same way as a locked phenom II cpu, with raising the fsb that increases frequency and auto sets voltages/ram etc, but they should all be able to be manually changed but for my oc my board did it for me and not the best knowledgable since i havent overclocked a apu, but if their similar to a locked phenom II then look for a thread about that, srry couldnt help more dont have time at the moment to give step by step help
Ok thanks think I will just leave it alone for now. I dont wanna mess it up
