Help, Overclockingproblem !!
GT2003
8
Hi, I have a Albatron PX845PE Pro II mobo with twinmos pc3200 512 MB memory with winbondmodul, p4 2.4/533 and a radeon 9700 pro.
I have the fastest settings On my radeoncard
My problem is when a run a 3dmark 2001se test with just the orginal settings(133x18=2400mhz)(ddr 333)
I get about 11000 3dmark 2001se points.
When I overclock my sytem to 166x18=3000 and ddr to 415 I
only get 7000 3dmark 2001se points.
I have direct x9, catalyst 3.1 driver, intels latest driver
and a fresch xp-system.
I have tried diffrent options in bios too. (defult)
I have 6 hd, 2cdrom, 1 network card, 1 radeon 9700 pro, 1 soundblastercard, 1 floppy and 2 120mm papstfans in my system...
Do you think it can be my psu 300w that cusing my problem?
maby I need a bigger one?
Can someone help me with this problem!
I did a test today and incresed the cpu voltage from 1.525v(defult) to 1.625v and evrything else standard.
Then my 3dmark score drop from 9600 to 5700.
When I did the test I disconnect 4 hd, 1 fan, and 2 cd drives, can it be my powersupply anyway!?
<P ID="edit"><FONT SIZE=-1><EM>Edited by GT2003 on 02/22/03 11:13 AM.</EM></FONT></P>
Possibly, but what are your temps looking like? 3dmark 2001 i sdependent on CPU, and P4's clock down at higher temps. Overclocking without real good cooling can actually run slower.
Please post in one forum, not all of them!
<A HREF="http://tekkoshocon.com/" target="_new">http://tekkoshocon.com/</A> Southeast Pennsylvania gets an Anime Convention!
Its possible on the power supply too. Download Mother board monitor and check your voltage levels.
Wait a minute, (last post until you reply), just looked at your specs.. 6 hard drives 2 cdrom and all that other stuff?! Im suprised you can boot, lol. Im guessing it is the power supply, but you would be crashing a lot.
With that setup I bet on the PSU... where can I leave my money and collect it after I won the bet?
My dual-PSU PC is so powerfull that the neighbourhood dimms when I turn it on 😱
hmm, I disconnect my 2 cdroms, 4 hd, 1 120mm fan.
same results, mayby it´s not enough power for my system 🙁
Well if you got a low quality PSU 300W will still be to low for a Radeon 9700 and that CPU.
But it also could be that your memory timings went down when you increased the FSB.
