Ok I bought/built this system from a barebones a couple years back. I been trying to squeeze a little more performance out of it for gaming to get me by for another year or two before i build a new system.
Specs,
Raidmax smilodon case, 600w cheap power supply, Asus P5B SE mobo, q6600 cpu, 9600gt vid card,running vista 64 ultimate, 4 gigs ram not sure what the ram is but here is what 3dmark 06 is saying it is when i scan my system...
Form Factor DIMM
Frequency 533.0 MHz
Slot DIMM_A1 [BANK0]
Manufacturer Manufacturer0
Type SDRAM
Type Details Synchronous
Enabled Size 1.00 GB (4.00 GB Total)
Total Bit Width 64 b
Data Bit Width 64 b
I thought my barebones was suppossed to come with 800mhz ddr2 ram but not sure if this ram is crap or what?
Anyway i have not flashed new bios- still using the ones the mobo came with, Today -I just downloaded latest nvidia drivers for my card, defragged, and in bios set CPU to 20% overclock, I then overclocked my 9600gt using 3dmark 06 to check for stability.
My vid card stock specs were 650 core 900 memory and found 750/1050 to be stable in 3dmark 06- although I only let it run once- not for hours as I read some ppl do.
Anyway- fired up AION to play for first time since overclocking, went fine for about an hour then the game crashed and system froze. So - I dropped the vid cards core and memory speeds down to just a little over stock (700/1000) and loaded up the game again- same crash/system freeze after about 2 hours.
I went into my bios and dropped the overclock profile down from 20% to 10%.
Havnt tried it out yet - I figured I would come here and ask first before I screw things up.
The problem Is- every few years I decide to build a new PC and go all ocd - reading researching about everything- but then a year or so later when I go to tweak anything with my system I already forgot everything i learned from when I built the thing- LOL.
Anyway- Im wondering if the ASUS bios on my p5b se mobo are decent enough to achieve decent overclocking.
I would like to get my Q6600 running at 3.0ghz with stock air cooling.
In my bios I can choose from
5%
10%
15%
20%
30%
overclocking...
Is this all there is to it or will I need to adjust memory voltage timings ect?
Any idea why im getting game/system crashes?
Thanks for any help! 😀
Specs,
Form Factor DIMM
Frequency 533.0 MHz
Type SDRAM
Data Bit Width 64 b
5%
10%
15%
20%
30%
overclocking...
