Help paste on mobo!!!!
Red8
512
Help please I got a small strand of the paste on my mobo and it's only on the flat part and not on any components but it is in this small silver crevice is this paste conductive with it fry any thing and do I clean it off please help hurry it's the paste that came with the coolermaster hyper 212 evo please helps its on a msi 970a g43 mobo
If you have any isopropyl alcohol (rubbing alcohol), dab a cloth (lint-free preferably), and gently rub it completely off the mobo. Then let it completely dry out before booting the system up.
Okay thanks it looks clean none on there from the naked eye I used a tip and 70 percent isop alcohol to rub it off u think that would do also I used another quip to dry immediately after I wiped the spot
