So my pc turns on in a weird way… (video will be attached) it’ll click a 3, or 4 times whilst the rgb flickers before it boots, wondering if it’s a failing psu or not. I jsut upgraded my motherboard and aio, so wondering if I also did something wrong, when the pc is on temps are comfortable and it runs stable. Side note I have my case fans not using the regular daisy chain controller but rather have the pwm headers plugged into the mother board ( headers are 3 pin) motherboard has 4 prongs and the extra rgb daisy plugged into my aio daisy chain… wondering if that could be causing the problem as I’ve removed the stock controller which had a sata power source
attached is a link where you can see what I mean,
tech4gamers.com
case: coolermaster mastercase h500 ( using stock fans) 120mm 200mmx2
Cpu: Ryzen 5 3600
Mobo: rog strix b550 f gaming wifi 2
Gpu: gigabyte radeon eagle 6600xt
Ram: xpg ddr4;8 gb x2 3000mhz
Aio: aorus waterforce 240
Psu: thermaltake toughpower 750w 80+ gold modular
nothing is overclocked
everything is plugged in exactly as to mobo instructions and aio except the rgb for case fans. It never did this before the upgrade!! Also fairly sure as I was told by people at Canada computers that my psu wattage was more than sufficient!
https://youtube.com/shorts/f3MEuGK63Rg?feature=share
anything helps!!
Cooler Master MasterCase H500 ARGB Mid-Tower Case Review
Cooler Master mastercase h500 review with its killer looks, dual front covers, 200mm ARGB fans, glass panel, & good build quality.
Cpu: Ryzen 5 3600
anything helps!!
