Hello everyone,
I recently built a new PC and have been using it fine for the last couple of days. My displayport monitor had a loose connection (i didnt know if it was the cable or graphics card port) but every time i would move a cable at the back, the monitor would go off. So i pulled it out and all 3 monitors went off this time, and would not come back on, but the computer was still on. So i couldn't see the screen to re-do the monitor settings. So i pressed the reset switch on my case and when the PC started back up i could hear the start up sounds but no picture on any of the screens. So i pulled out one of the DVI monitor cables, and the PC just shut off, as if i had pulled out the power cable. I put it back in and pressed the power button but nothing, the PC will not turn back on at all. The power LED (green) on the motherboard is on, and the LED on the Ethernet port is flashing, that's it for any signs of life from the PC. I'm certain it is all wired up correctly because i have been using it for the past could of days with no problems. Can anyone help me with what to do with this problem, i have no idea where to start!
Thanks.
Thanks.
