[SOLVED] Help pc does not boot how it shoud!
May 16, 2019
Specs Processor: Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz
Video Card: NVIDIA GeForce GT 630 1GB GDDR5 Gainward
RAM: 4.0 GB
Operating System: Windows 7 64bit
PSU: 450w
Motherboard: [Intel : DP43TF] Intel P45 Express
Hello, so when i try to power on my pc it does boot normally but when i get to the windows 7 loading screen all of my fans go full speed and the pc restarts in a loop, but if i boot the pc in safe mode it works, if i boot in safe mode and then reboot from the start button it boots in normal windows like is does not have any problem.
I shoud mention that when i boot the pc is beeping one time only.
In windows safemode can you disable all the windows 7 startup programs
Beep codes for discontinued (legacy) desktop boards
Beep StateMeaning
1 long beep followed by 2 short beepsVideo configuration failure (a faulty video card or no card installed), or an external ROM module does not properly checksum to zero.
1Refresh failure
2Parity can't be reset
3First 64K memory failure
May 16, 2019
Beep StateMeaning
1Refresh failure
Yes but even when i install a fresh os without any software installed happens the same when i try to boot.
When i first bought that moba it was giving me some kind of cmos battery failure, i changed the cmos battery and did not happen no more.
I think the problem is the moba but i want to be sure before i buy another one.
Thread starter Similar threads Forum Replies Date
G Systems 7
H Systems 2
Similar threads
