Help pc freezed while gaming and now prompts me too select proper boot device
luizluz
11
Yesterday i was playing overwatch, when suddenly the pc freezed and i wasn't able too press cntrl +alt+del, só i forced the shutdown. Then when i restarted i was prompted to select de proper boot device. I've already check de boot priorities but they are correctly, both drives are recognized in bios but don't boot. I also tried changing the sata ports, connecting and disconnecting every connection( Ram, CPU, GPU, drives), changed the boot from legacy to UEFI.
What could be?
Ps: sorry for the bad english ; )
My specs:
Cpu: i7 7740x
GPU: gigabyte 1050ti
Psu: evga 550w 80+ gold
Mobo: msi x299 sli plus
Storage: ssd kingston a400 240 gb
Wd caviar blue 7200 RPM 1 tb
Ram: kingston 4gb 2400mhz
crucial ballistix sport 4 gb 2133mhz
Do you have a spare drive to test with? Take the preexisting drives out of the build, then install windows on the test drive to see if it will boot.
Unfortunately no =(
Hmm, i guess i can borrow one from a friend to do the test, i'll try tonight these steps.
Tks =)
Thank you man, i borrowed the Hd with a friend and worked like magic.
