[SOLVED] Help: PC restarts randomly
Bobkwando
11
Since yesterday my PC has been restarting by itself at unpredictable times. No blue screen. The link below is a event viewer file showing errors before a restart, I do not know what is causing the problem. I have updated all my drivers but to no avail. I also stress tested my GPU for 15 minutes as crashes mostly occurred when gaming, and it crashed 1/3 of the times so I'm not sure what to make of it. Please kindly advise on possible solutions!
http://
My canned random reboot Rant
Random reboots are usually caused by the PSU, the RAM or software AND in that order of likely-hood.
PSU - If you can borrow/swap a PSU for testing. sibling/friend you can swap out the PSU and each system will be testing the other.
RAM - run the system with one stick of RAM see if stability returns if not Test all the RAM with memtest 86 for three passes or overnight. if you get no 0 errors after more than three passes the ram is good. with the random reboots I would suggest running this test after the PSU swap or after the PSU has been cleared.
Software - Drivers or other issues can cause reboots. Boot to a linux distro on a USB drive. mint linux will boot to memtest86. you can run the OS from...
I had a Corsair Hx750w begin to restart the pc on me. Would restart playing games or just browsing, maybe twice a week that happened. Could stress test prime95 or ibt and it would be fine. It was random.
First i tried another set of ram. Still did it. Reboots like that are usually either ram or psu. Replaced psu and haven't had a reboot since, going on 4 months now. Psu was obviously faulting in my case, bad caps probably.
Evga Supernova G2 if you consider.
Software - Drivers or other issues can cause reboots. Boot to a linux distro on a USB drive. mint linux will boot to memtest86. you can run the OS from the USB and await reboot.
end canned rant
