Hello everyone,
so my PC shuts off and restarts when i start stress test software 3d Mark11, when i try to open a game after the loading screen and sometimes while alt-tabbing between windows.
Stress test will not even begin, because my PC is being shut down almost directly after the start.
I have a device to check the power consumption of a device, and it shows no more then 100 Watt consumption, before my system shuts down.
Sometimes i open chrome, watch YT, Twitch and Reddit simultaneously and play Hearthstone. When Chrome runs in background and i play the game nothing happens, but when i switch windows with ALT+Tab it shuts down my PC sometimes.
Until now everything was actually fine.
My setup is 2 years old:
CPU Intel Core i5 4690K 4x 3.50GHz So.1150 BOX
VGA 4096MB MSI GeForce GTX 970
MSI Z97 GAMING 5 Intel Z97 So.1150 Dual Channel DDR3 ATX Retail
8GB HyperX Savage rot DDR3-2400 DIMM CL11 Dual Kit
550 Watt CoolerMaster G550M Modular
SSD 128GB Crucial MX100 2.5"
CPUK Scythe Mugen 4 Tower Kühler
HDSA 1000GB WD Blue WD10EZEX
I checked the temperatures with HWMonitor, and they are fine, for CPU - 40-55 degrees, and for GPU - 60-70 degrees. I think that one sensor is dead, cause it shows 127 degrees, and i havent seen anything smoking right now 😉
Can it be that simple and my PSU is failing?
Could you please help?
Regards
I just did some additional testing. While i run CPU Stress test, Watt intake rise to 140 but everyting is fine. But when i start GPU test, my PC shuts down immediately 🙁
@GhislainG unfortunately not :/
Regards
