Hi! this is my first time posting here although I've been lurking forever, I am not really "tech-savvy" although I've read up tons now so I know the basics, I'd like to thank in advance the knowledgeable person(s) who will go through my post (which i will try to structure as clearly and detailed as possible) and provide feedback THANK YOU so so much.
My Current setup: (upgrade Budget: ~$1200)
Operating system: Windows 10 Home 64-bit
Motherboard: ASUSTeK COMPUTER INC. Z97-PRO GAMER (SOCKET 1150)
CPU: Intel Core i7-4790K @ 4.00GHz, Haswell 22nm Technology
CPU cooling: Stock Fans
RAM: 16.0GB Dual-Channel DDR3 @ 799MHz
GPU: 4095MB NVIDIA GeForce GTX 980 (ASUStek Computer Inc)
Storage: 1TB HDD, 250GB SSD
I've had this PC for a little over 4 years now and am looking to upgrade and add liquid cooling too! My main goal is STREAMING games while maintaining high FPS as I play competitively (Fortnite). I usually get ~140-180FPS (240Hz monitor) all settings on low (shadows off etc), which dips lower than that when I stream (using Xsplit software).
Questions:
1) I was looking at RTX 2070S or GTX 1080ti, they seem like significant upgrades, however will my CPU create a bottleneck and make it useless?
2)I purchased a H100i Pro Corsair liquid CPU cooler, should I install that if my CPU temps reach 70-72 while im gaming?
3)Do I need to change my CPU for any upgrade i make to my GPU ?
4) what about RAM? is it worth the upgrade to 32GB ?
Feel free to skip these questions and just show me the way! again thank you for taking the time to familiarize yourselves with my case!
Questions:
