Question Help - PC wifi speed 1/4 of phone wifi speed
Aug 3, 2023
Hi. Thanks in advance for any help. Ookla speed test on Samsung A13 returns just over 100Mbps but Win10 with Asus pce-n10 11n Ookla test returns 21Mbps. Obvious difference is phone is 5Ghz and PC is 2.4Ghz, but shouldn't that still be able to get up to 150Mbps, as is shown as max in the wifi status screen? Would IPV6 matter? Does not seem to be enabled in my router so it shouldn't matter, since it would be off for phone too. Any thoughts?
Make and model of your wireless router? Check to see if said router has any firmware updates pending. As for your wireless adapter, have you tried uninstalling device/drivers and then manually reinstalling the latest drivers in an elevated command, i.e, Right click installer>Run as Administrator?
Make and model of your motherboard? Check and see if there's any BIOS updates pending for your motherboard.
