Corsair Hydro H55
cooler master seidon 120
deepcool maelstrom 120
which of the 3 is better?
currently i used deepcool gammaxx s40 but its so big for a mid-tower case and way to hassle, and i cant even put a ram with heat spreader because of its size
so which is better? which gives the lowest temp?
or do you have anything so say or comment like suggestion
thanks in advance guys, you rock!
