Which processor should I use for budget build? I'm in computer science, so on top of general use I'll be running IDEs, development tools/simulators, and I also use Adobe CS3 often. I'm pretty set on cheap, but the $20 bump to the 4370 would be ok if it makes a difference at all. Is there enough performance increase (for my uses) to go ahead and spend another $60 on the 4690K?
The options are:
I3-4160 ($125)
I3-4370 ($146)
I5-4690K ($209)
My current parts list was created from hand-me-downs and sales (only spent $110 so far!):
Mobo - GA-H81M-HD2
RAM - Corsair Vengeance LP 2x4GB 1600Mhz
SDD - Samsung Evo 850
GFX - Quadro 4000
PSU - Corsair CX750M
Thanks for any help!
The options are:
I3-4160 ($125)
I3-4370 ($146)
I5-4690K ($209)
Mobo - GA-H81M-HD2
GFX - Quadro 4000
