So I have my computer inside of a cabinet and it can get hot in there.
Pictures:
View: http://imgur.com/a/lcBQrv3
My idea is to cut out the front panel of cabinet door and replace with metal mesh and then use two small fans I have with a temperature gauge to active fans when it gets to certain temperature. I want the fans to be side by side so I want to put something flat on the computer and then the fans on that.
I'm thinking of using plexiglass but wasn't sure if that was a good idea or not due to temperature in there or possible electric conduction. Any advice or alternatives?
Pictures:
