Help picking my psu
Any cheaper than this is lacking quality.
XFX 550W.
CPU: AMD FX-8320 3.5GHz 8-Core Processor ($138.89 @ OutletPC)
Motherboard: Asus M5A97 PLUS ATX AM3+ Motherboard ($67.89 @ OutletPC)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory ($29.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($45.88 @ OutletPC)
Video Card: PowerColor Radeon R9 270 2GB TurboDuo Video Card ($127.98 @ Newegg)
Case: Azza SIRIUS ATX Mid Tower Case ($30.98 @ Newegg)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply ($55.99 @ SuperBiiz)
Total: $497.60
Generated by PCPartPicker 2016-01-18 17:09 EST-0500
Total: $55.99
Generated by PCPartPicker 2016-01-18 17:11 EST-0500
that one is out of stock and its expensive in other places
Check the link I posted, same PSU, $69
do you have one thats around the $50-$60 dollar range
$10 is worth powering your system properly and not create a fire hazard in your home at worst, or at a minimum have your parts not work correctly together.. If you can afford the rest of the parts you need to find that extra bit to afford this.
seasonic s12ii 550 bronze rated at 80+ bronze is this one bad my gpu only need 450 if not ill go for the one you told me
Your whole build wont exceed 375w.
You can Get the SEASONIC 520W.
But I would get the XFX550W , it's better quality.
Case: Azza SIRIUS ATX Mid Tower Case ($45.98 @ Newegg)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply ($50.99 @ SuperBiiz)
Total: $507.60
Generated by PCPartPicker 2016-01-18 17:43 EST-0500
