Help picking out a power supply
Aug 15, 2018
9
Hello Community,
I need to find a power supply with over 500w and to fit all the connection below. I don't care if its modular or not, but I do prefer it to be modular. any suggestions?
Computer Summary
Operating System
Windows 10 Pro 64-bit
CPU
Intel Core i5 3475S @ 2.90GHz 43 °C
Ivy Bridge 22nm Technology
RAM
16.0GB Dual-Channel DDR3 @ 798MHz (11-11-11-28)
Motherboard
Dell Inc. 00F82W (CPU 1)
Graphics
VG2228 SERIES (1920x1080@60Hz)
512MB ATI AMD Radeon HD 5450 (Dell) 45 °C
Storage
931GB Seagate ST1000VM002-1SD102 (SATA ) 36 °C
Optical Drives
TSSTcorp DVD+-RW SH-216DB
Audio
Realtek High Definition Audio
Corsair CX(2017) or CXM 450w.
Seasonic S/M12-II 520w.
With a HD5450, all you need is something decent that's over 350w. The only reason you'd need 500w+ is if planning on upgrading the gpu, which for that cpu a gtx1050ti or gtx1060 would be a good match, either of which will be just fine on a decent 450w+ psu.
