Help pleas fast
Mitch_15
84
I had a problem that my pc would start but didnt got any view on my monitor just got a new gpu and yesterday everything worked i was so happy but now it doesnt any more it started up i saw a screen from msi for overclocking and i clicked save mode and then it restarted and now i dont see any rhing any more
Remove your GPU and try to start your PC in safe mode. Uninstall ALL GPU drivers and then shut down your PC. Plug your GPU back in and only install driver from AMD or NVIDIA website. Don't install any third party software like MSI afterburner. Let me know if this helps.
Start the computer in SAFE mode. Keep hitting the F8 key. Choose to only boot with the least amount of drivers and hardware.
If you have MSI Afterburner, uninstall it in safe mode. If you do not have MSI Afterburner, remove the video driver and all related software.
Then boot the computer as normal. Download and install a free program called Display Driver Uninstaller.exe - that program will completely clean up driver downloads from AMD and Nvidia. Get it here: http://www.majorgeeks.com/files/details/display_driver_uninstaller.html
It sounds like your power supply is too weak to drive the video card, especially when overclocked.
EDIT: Remember to download and install new video drivers after uninstalling old drivers.
Latest posts
