Sorry for long post, been troubleshooting this all afternoon.
Specs: Win 7 64-bit, Asus P8P67 LE mobo, i5-2500K, Arctic Pro 950W PSU.
Started off when I decided to follow a YouTube guide to overclocking this mobo. I have an i5-2500K and it was only to 4.5GHz so I don't think the values were too high, although I did get the memory voltage wrong (guide said 1.65V but RAM is rated for 1.5V). Re-booted and everything was fine... should have stopped there.
However I noticed my BIOS was out of date so decided to flash the new one (3801). Went into BIOS and used EZFlash utility, everything went fine until it asked to reset, then screen went black but PC didn't reboot. Waited a bit but after a while decided to hit power button. That's when things went pear-shaped.
When I next tried to restart, nothing happened - no fans moving, no lights, no screen. Thought I must have screwed up BIOS update, so I reset BIOS (took out battery for 10s) and thankfully I got POST. However I was getting errors, and although I've managed to boot into Windows (writing this from same PC) there is something really wrong.
I get the following problems when starting up:
- PC will boot but I get no POST. Usually solve this by resetting BIOS by removing battery.
- when I get POST, I get an error saying PSU had a power surge and the BIOS protection kicked in, press F1 to reset settings....
- ...or, I get "CPU Over Voltage" and "CPU Over Temperature" errors.
- was also getting "Keyboard not found" errors using my old Microsoft USB hub keyboard, which attaches via both PS/2 and USB ports. At one point I managed to get to Windows login screen but wasn't able to enter password. Entered Guest account instead and tested keyboard, it was behaving very strangely, either not responding to key press or responding by entering two characters instead of one. Decided to use daughter's USB keyboard instead to eliminate possible keyboard problems, however other errors still happening.
- once I get into BIOS (which shows as updated 1803 version), initial "EZ Mode" screen shows wildly fluctuating values in the monitor section for voltage, temperature and fan speeds, the values bounce between what look like normal values and maximum values (bar goes red). When I go into Advanced mode and try and access the Monitor section however, BIOS freezes and I have to hard reset.
- I have tried setting Default and XMP configs but errors still persist.
- a couple of times I've tried re-flashing the new BIOS, but instead of getting a progress bar it just says it's finished and prompts me to reset. Maybe it recognises it's already updated?
Also worth noting, CPUID HWMonitor program is showing a more limited set of values now than it was before I flashed BIOS (e.g. before it was showing voltages, fan speeds and temps for mobo, now it's only showing two temp values (TZ00 and TZ01)).
I'd appreciate any tips, as far as I can tell it's either a dead BIOS battery, a failing PSU or somehow the BIOS isn't properly flashed.
EDIT: a bit disappointed not to get any suggestions for a few days.
Since posting the problems have continued. After some searching I found there were many problems updating the BIOS on this mobo, so I followed some advice and re-flashed the ME region from a boot disk following this guide; however on re-boot I still noticed the wild sensor readings. As I had some important stuff to get on with I just booted into Windows and have keep the PC running since then - it's been a couple of days now so I don't think it's PSU issues, I'm betting on the BIOS battery at this point.
EDIT2: Installed Probe 2 and this is the result:
