HELP please.. Blue screen 0xc0000225 and memory_management
chocode
My tablet kept on showing this error memory_management which caused some restarts after a couple of uses(kept using it still). Then after that it wouldn't start saying there's an error on some driver, aswndisFLt.sys. I think its because i installed free avast internet security idk. Easy fix please, thx :)
Avast! Firewall Driver (aswndisFLt.sys) returned a error code 0xc0000225 which is STATUS_NOT_FOUND
most likely going to be a bug in the network driver for your device.
(this can be any wired or wireless driver on your machine. IE ethernet wireless driver or maybe a bluetooth wireless driver not responding correctly. All you can do is update the wireless drivers on your machine or remove the firewall driver (assuming it is upto date)
the avast firewall driver crashes when the wireless network driver does not respond correctly or within the correct time frame.
well i cant update that, im stuck can't load the os. All i can access is startup settings.
[BLUE SCREEN]
Your PC needs to be repaired.
Error code 0xc000007b
You'll need to use the recovery tool on your installation media. If you don't have any installation media (like a disc or USB device), contact your system administrator or PC manufacturer.
2 Press F8 for startup Settings
3 Press ESC for UEFI Firmware Settings
THX BTW
