Help please! Compatibility?
VeTo Vortex
8
Hey guys,
I just want to check here, you're all the experts. Is the following build possible/compatible? Thanks a lot for any responses!!
ASUS VE278Q Black 27" Full HD HDMI LED Backlight LCD Monitor w/Speakers
CORSAIR TX Series CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Active PFC Compatible with Core i7 Power Supply
Microsoft SIDEWINDER X4 Keyboard - Retail
Corsair Vengeance M60 Black 8 Buttons 1 x Wheel USB Wired Laser Performance, FPS Gaming Mouse
ASUS SABERTOOTH Z77 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Intel Core i7-3770 Ivy Bridge 3.4GHz (3.9GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I73770
Intel 520 Series Cherryville SSDSC2CW120A3K5 2.5" 120GB SATA III MLC Internal Solid State Drive (SSD)
IN WIN GRone White 0.8mm SECC Steel ATX Full Tower Computer Case
GIGABYTE GV-N670OC-2GD GeForce GTX 670 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
ASUS Black SATA DVD-ROM Drive Model DVD-E818A7T/BLK/B/GEN
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9R
CORSAIR Hydro Series H60 (CWCH60) High Performance Liquid CPU Cooler
If this is a "high end," fps gaming computer then listen to me, and supplement the following links into your build:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130645 MSI Motherboard that Sabertooth is a waste of money this board does the same exact thing
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504 You don't need an i7, the i5 is the same processor without hyper-threading, something game engines don't use. You will have the same FPS with either processor except this one saves you 100 dollars.
Samsung...
Hey, thanks for the quick reply. It's going to be a "high end" FPS gaming computer. Mostly BF3, Crysis 2 and BO2. Could you recommend a motherboard from newegg.ca that would work well? Thanks!
Samsung 840 Pro, Plextor M5P, and finally Corsair GTX Neutron These are the only SSD worth buying. The samsung has the best performance, followed by the Corsair, followed by the Plextor.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127685 MSI 670, will stay cooler and will do it with 2 fans. Also better for overclocking.
And corsair released a newer version of that mouse, http://www.newegg.com/Product/Product.aspx?Item=N82E16826816009 upgraded the sensor/subtle changes to the grip.
-Prax :sol:
Thank you Praxeology! That helps so much. I will use the links you provided, and that saves me a bunch of money too. Sweet! Will everything else be compatible with what you recommended. Thanks a lot man!
Yes it meshes together really well, perfectly compatible. MSI motherboards also come with OC genie, a bios tool that makes OC very easy, and incredibly stable, which is a nice extra. Buy it, and enjoy, this system will dominate. You got to pick an SSD, all are good(I can't choose between those 3), and grab some arctic silver 5 thermal paste Don't forget to close the thread once you are confidant in your purchases,
-Prax :sol:
Great! I really appreciate your help bro. Thanks so much! :)
