Did you totally replace your old HDD. or is it still your main boot drive? If you totally replaced it, did you first clone your system from the old drive before replacing it? If not then you are missing drivers that your laptop needs in order to work properly. Laptops are very particular about having the correct drivers. You can't just replace the HDD without allowing for the correct drivers.
