Help please: FX5200 and JB Nightfire - NO GO?
STEFANIE
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
HI Guys and gals
I have just replaced an old Riva 128 with a MSI 5200 128MB, now I find 007
Nightfire will not even start, it just bombs out to a black screen. It is
definately related to the FX5200 as I also have one of these ion another
machine and again no go with Nightfire.
I have tried Direct X8 and 9, tried on Win ME, 98, and XP.
I have used 12 month old Nvidia drivers, six month old and the very latest,
plus of course the MSI ones, no difference.
I have of course removed old versions first and even used Driver Cleaner in
between.
I have tried all possible configuration options I can find, but Nightfire
will not run on either PC.
I have thrown the old riva card in an old Win 98 P450 machine and Nightfire
does start up, all be it a bit slow!
Please help
Regards
Stef
G
Guest
Guest
Nightfire works well on my FX5200. Just make sure you have the most up to
date video and chipset drivers.
"Stefanie" <newsman@hotmail.com> wrote in message
news:c8cvnj$jug$1@news8.svr.pol.co.uk...
> HI Guys and gals
latest,
in
> between.
Nightfire
> Please help
> Regards
> Stef
G
Guest
Guest
> HI Guys and gals
latest,
in
> between.
Nightfire
> Please help
> Regards
> Stef
Have you tried removing the game, and then installing it again. Might be
that there are some settings changed because of the switch. And Do you also
have the latest patches installed for nightfire?
Greetz Rubbing
STEFANIE
Yes I have tried both re install and have put the only patch I can find on
(1.1)
Thanks for trying.
Stef.
"Rubbie" <bjojk@nospam.demon.nl> wrote in message
news:10al1jj5v310b24@corp.supernews.com...
> > HI Guys and gals
007
is
> latest,
> in
> > between.
Nightfire
> Nightfire
> > Please help
> > Regards
> > Stef
also
> Greetz Rubbing
ANON
415
I had similar probs trying to run Simcity and RRTycoon, either would run
then quit or not run at all.
Eventually after removing drivers/cleaning/reinstalling - several times -
they all worked. Can give no definative explanation as to which action cured
the problem
news:c8e7ip$l1j$1@news7.svr.pol.co.uk...
> (1.1)
> Thanks for trying.
> Stef.
> > > HI Guys and gals
> 007
> is
another
> > latest,
Cleaner
> > in
> > > between.
> Nightfire
> > Nightfire
> > > Please help
> > > Regards
> > > Stef
> also
> > Greetz Rubbing
