Help Please Gpu and Cpu !! (Comparability)
Encinity
Commendable
Nov 7, 2016
14
PS. I'm Not Good With Pc Compatability
I just got battlefield 1 and im thinking about getting a GTX 1070 for my birthday :)
Right now for my GPU, I have an AMD Radeon HD 7700 Series and it doesn't work very well with Battlefield 1.
My question is Will the GTX 1070 run well with my CPU wich is an AMD FX(tm)-6100 Six-Core Processor or do I need to upgrade to something better.
Also if there is anything else that I must need to run the GTX 1070 or for it to be compatible please let me know or if there are any cards that you would recommend for the CPU that I have to run battlefield please let me know.
Thank You
This would be a huge upgrade over what you have. Spend just a little more and you could get a 480 or GTX1060.
What psu are you using?
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($184.99 @ Newegg)
Motherboard: Gigabyte GA-B85M-DS3H-A Micro ATX LGA1150 Motherboard ($55.98 @ Newegg)
Video Card: MSI Radeon RX 470 4GB ARMOR OC Video Card ($169.99 @ Newegg)
Total: $395.96
Generated by PCPartPicker 2016-11-07 23:14 EST-0500
Total: $395.96
Thank You so much for responding it helps alot :)
TBH I really don't know what PSU I am using
Is there any solution with the CPU that I have to know to just upgrade the GPU to run battlefield 1 smoothly maybe like a GTX 1050 Ti? Because truly I was just looking to upgrade the GPU for a low price to where I can still play battlefield 1 and games like that smoothly.
If you have any suggestions that would be great to the GPU or would you recommend just building a new PC because of the CPU I have now?
Basically is their a way to where I can just upgrade the GPU and be all good? and if so what card should I get?
Thank You so much for responding it helps a lot :)
Okay great that sounds good to me :). Now wich card would you recommend for the gaming I want to do the GTX1050 ti or the RX470 for the CPU that I have. Or is there a better card out their that fits my criteria ?
I also have a question, I have done some research and how found that the RX 470 is better than the GTX 1050 ti :) but the question is I also saw the GTX 1060 and the RX 480. Would you recommend with my CPU and what I want for the gaming aspects of it, sticking with the RX 470 or going with a GTX 1060 or RX 480 (if so which one out of the two)? Thank You
Okay sounds great. Thank you so much !! This really helped :)
