I have a small problem I have a SSD 500GB drive, I have it partitioned as C for windows and main programs and A: which is the same drive but just separated from the MBR.
Everything was suppose to be setup were everything was installed on D drive and everything else on A : as far as main programs but it still filled up and didn't realise it until it was to late . I install everything on a different hard drive ( D: ) and it works great and still plenty of room on those drives but I cant seem to extend C I guess because its a boot drive or MBR? I can use the space from A : which is the same drive im just not sure how to do it.
I'm just trying to figure out how to extend the C drive so that it's not full. I have plenty of other hard drives even connected that are either allocated or unallocated that can be set up for this to work correctly with your advice but I just don't have time to reinstall everything. So once again via the screen shot you C: drive as well as the A:drive. This is just one hard drive, it's actually a 500gb SSD drive and all IM looking to do is extend or add space to C; drive somehow. Any help would be greatly appreciated.
