Hi
I've had troubles with this before, and it was caused by a file called stij.exe and I managed to remove it, but it came back a couple of times.
The problems I'm having now are identical to when I had problems before with stij.exe, but this time I can't see any stij.exe in the processes tab for windows task manager. Does anybody have any idea how to fix this? Are there any other files like stij.exe that cause the same problem?
Any help would be appreciated. Thanks
