HELP PLEASE...My sound card doesn't fit into my computer!!!
G
Guest
Guest
i brought a M-Audio delta sound card for my desktop computer (acer aspire X3200)but when i tryed to insert it into the pci slot it was to big for the tower casing. is there anything i can get to insert the sound card into then connect to the pc? or any other option rather than buying a full size tower? any help would be appreciated. thanks,
James
G
Guest
Guest
thank you.. i just checked that out but that wouldnt be appropriate as i need this sound card as im trying to set up a home studio. really appreciate ur help tho, cheers.
Raidur
2,365
You could buy... a saw?
If that doesn't tickle your fancy you're stuck with buying a low profile (shortened for smaller cases) card or a new case.
