HELP PLEASE PCI-e = VGA ????
What you do is find the PCI Power Cables from your motherboard (probably have 2 (6+2) pin right?) what you do is discard the 2 extra pin and plug 2 6 pin into the GPU.
I know it can get confusing sometimes but it'll work out.
Hope it helped!
Good Luck!
Hope it helped!
Good Luck!
