Archived from groups: alt.comp.periphs.mainboard.asus (
More info?)
On Wed, 28 Apr 2004 15:31:24 -0500, nospam@needed.com (Paul) wrote:
>In article <edtv80tg16k9i1vrne5s03s9ng02hs2g3b@4ax.com>, test
><2boxers_at_comcast_dot_net> wrote:
>> I have the PP-DLW with 2 2.8GHz 533FSB processors installed.
>> I have 1 512 DDR266 (pc2100) unregistered module installed.
>> Video inits and here is what is displayed:
>> CPU : Intel(R) Xeon(TM) CPU 2.80GHz
>> Speed : 1.06 GHz Count : 2
>> Can anybody explain the Speed of 1.06GHz?
>> Please help,
>> I do not have much time left if I have to return anything.
>> Charles Wilkins
>And, what is "Ratio CMOS Setting" set to in the BIOS ?
>The default is [8], judging by the picture in the manual.
>Perhaps a value of [21] would help ? (21x133=2.8GHz)
>If that doesn't help, please post the revision number on the
>motherboard (printed in white letters, next to the name
>somewhere), the BIOS revision installed, the SSPEC five
>character code on the two processor etc. That will help
>identify any other issues.
>You can get some info here:
>http://www.asus.com.tw/support/cpusupport/cpusupport.aspx
>Are your processors a C1 or D1, or are they an M0 ?
>http://processorfinder.intel.com/scripts/list.asp?ProcFam=528&NoNav=NO&CorSpd=5467&SysBusSpd=5419&MfgTech=ALL&step=ALL&cache=ALL&PkgType=ALL&btnFOS=Filter+on+selections
>BIOS 026 and 027 contain microcode updates and support for
>new processors. 028 is the latest BIOS:
>http://www.asus.it/support/download/item.aspx?ModelName=PP-DLW&Type=All&SLanguage=en-us
>Using AMIBCP75 and CTMC, I can see BIOS 028 has support for the
>following Family Codes of Intel processors:
>0F0A,0F11,0F12,0F22,0F24,0F25,0F27,0F29
>For some reason, there are two entries for Family Code 0F25,
>which won't hurt anything. (They are loaded sequentially, until
>one "takes". Microcode patches are encrypted.) Maybe it is for
>the two different cache sizes of the M0.
>Check the family codes on your processors, and see if they are
>on the list.
>HTH,
> Paul
Paul thank you for replying.
21 did help. and the bios is rev 028 from the factory. thanks again,
Charles
