UPDATED: Complete. PC is up and running (scrunched down the screen using nVidia control panel) YAY it's complete. THANK YOU SO MUCH to everyone who helped ^_^
1.) [strike]For the SSD and HDD I am only tracking one cable so far (for each) but there are two ports? Is the bigger one for RAID (if so then I don't need to worry about that)[/strike] [done]
2.) [strike]Cable from the H320 unit, says to plug into PSU[/strike] [done]
3.) [strike]Cable labed "GPU Fan" but my GTX 780s have fans build in and no port, do I ignore this cable?[/strike] [seems like I do]
4.) [strike]PC Seems to be finished but can't get anything to show up on screen?[/strike]
The Build (minus a few components that I already had at the time)
http://pcpartpicker.com/user/LordValinar/saved/gwpmP6
