Help please.......
G
Guest
Guest
Archived from groups: alt.games.diablo2 (More info?)
DH plays the game. It keeps crashing. Does anyone know what he can do to
stop this from happening? He has tried it on all three of his computers
with the same results:-(
TIA
G
Guest
Guest
What / who is DH?
Does he receive any error messages? It will help if you post the exact
error messages, and the configuration of the computers he use.
G
Guest
Guest
"nnaoj5" <nnaoj5@hotmail.com> wrote in news:5bidnfR98bI7bUPfRVn-
pg@comcast.com:
> TIA
If it was a recent install to all PCs using same disks, I'd check the CDs as
well.
Do you have any video codec packs installed? The following was a big headache
for me for a long time when first installing D2 & LOD...
If so, see if you have FFDShow (video renderer) installed. FFDShow causes a
lot of games to crash because it tries to make itself the default video
renderer for ALL video (including Smak, Bink, and a lot of other video types
used in game CGs).
When in a game and a CG movie starts, FFDShow will have an icon in the tray
(if it is a newer version). If its an older version of FFDShow, you'll have
to look for it in Add/Remove Programs but codec packs usually do not create
an uninstaller for just FFDShow so you may be better off searching for the
folder called FFDShow or just FFD. If you find it and it doesn't have an
uninstaller, you may have to uninstall the entire codec pack.
Just a suggestion. Hope it helps.
~ThetaSigma
a.k.a. Br_Dalamar on BNET
