Help please !
Andrei_48
I have an :
Codename Ivy Bridge
Specification Intel(R) Core(TM) i3-3217U CPU @ 1.80GHz
Package (platform ID) Socket 1023 FCBGA (0x4)
CPUID 6.A.9
Extended CPUID 6.3A
Core Stepping E1/L1
Technology 22 nm
TDP Limit 17.0 Watts
Tjmax 105.0 °C
Core Speed 1795.7 MHz
Multiplier x Bus Speed 18.0 x 99.8 MHz
Stock frequency 1800 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AVX
L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 2 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 3 MBytes, 12-way set associative, 64-byte line size
Max CPUID level 0000000Dh
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 32 KB, 2 thread(s)
Cache descriptor Level 2, U, 256 KB, 2 thread(s)
Cache descriptor Level 3, U, 3 MB, 16 thread(s)
FID/VID Control yes
Turbo Mode not supported
Max non-turbo ratio 18x
Max turbo ratio 18x
Max efficiency ratio 8x
O/C bins none
Ratio 1 core 18x
Ratio 2 cores 18x
Ratio 3 cores 18x
Ratio 4 cores 18x
Temperature 0 50 degC (122 degF) (Package)
Temperature 1 50 degC (122 degF) (Core #0)
Temperature 2 46 degC (114 degF) (Core #1)
Voltage 0 0.89 Volts (VID)
Power 0 4.31 W (Package)
Power 1 1.80 W (IA Cores)
Power 2 0.37 W (GT)
Power 3 2.14 W (Uncore)
Clock Speed 0 1795.71 MHz (Core #0)
Clock Speed 1 1795.71 MHz (Core #1)
CPU-Z print <Removed>
My question is , can i upg my processor to i5 ?
No, It's BGA so it's soldered to the motherboard. Depending on the model of the system you would have to replace the entire motherboard and that is if the manufacture makes one with an i5 that will fit your chassis. I also removed the link with the NSFW images.
