HeLP PLEASE
Omnipotence
13
Hi in my bios settings there is like cas to ras min ras to this and all this which ones do i set to what for my ram specs like says cas 2 and 2-3-2-5 theres about 8 in my bios which ones do i change to 2-3-2-5 1t can u help me please
Model
Brand OCZ
Series Platinum
Model OCZ4002048ELDCPE-K
Type 184-Pin DDR SDRAM
Tech Spec
Capacity 2GB (2 x 1GB)
Speed DDR 400 (PC 3200)
Cas Latency 2
Timing 2-3-2-5
Voltage 2.6V - 2.8V
Heat Spreader Yes
Features Mirrored Platinum Copper Heatspreader
Enhanced Latency Technology
Recommend Use High Performance or Gaming Memory
If you don't know what those settings are, then I strongly suggest doing some research and understand the terms and impacts to memory. Like jit said, just set it to auto-detect and you'll be fine...
