[SOLVED] Help plz
Oct 2, 2020
5
So this is my first computer and it's just giving me such a huge headache, I'm having Pc problems, games keep crashing which sometimes result in a blue screen and sometimes it will just fully reboot without the blue screen
so far i have had to replace faulty ram
replaced the ram
problems persisted
Had someone look at it stating it was a motherboard problem
I have had my motherboard tested by who i purchased it from and they said it was in full working order,
Had another person look at it and stated that the bios was corrupted on my motherboard and has updated the bios and reinstalled windows
And now we are here to today, games still crash.
I have updated all drivers for my gpu, checked all states of my storage drives, run the memory diagnostic tool and it says ram is fine, my temps are fine
I'm on the verge of headbutting my PC fml
My Pc Specs:
CPU: R5 1600AF
RAM: Corsair Vengeance RGB PRO 16GB 2x8 3600Mhz
MOBO: Aorus B450 Pro Wifi
GPU: AOG Strix 5600 XT 6gb
Storage: Samsung Evo 970 250GB (Boot Drive)
WD Green 480GB
Seagate Barracuda 1TB
PSU: EVGA Supernove G1+ 650W Gold+
To avoid problems, you should use ram that has been tested as OK on your motherbaord with your CPU.
For the error, try a new graphics driver.
So - games keep crashing which sometimes result in a blue screen and sometimes it will just fully reboot without the blue screen
What's the max temp your CPU gets to while gaming?
And your GPU max temp?
What case have you got?
Is your ram listed on your motherboard memory QVL?
Do you get any error messages?
Are you running your RAM at 3600MHz? The 1600AF is a Pinnacle Ridge CPU and the highest RAM speed your motherboard supports for Pinnacle Ridge is 3200MHz.
Does it run at 2133MHz (no XMP)?
I think you need to look at your motherboard memory QVL for your CPU.
If your memory is not on it then see if you can buy some ram that is.
The Qualified Vendors List shows all the ram that has been tested as OK.
CPU hits 63 Celsius
GPU hits 51 Celsius
Fractal Design Meshify C
My ram isn't listed on the QVL
I had KMODE_EXCEPTION_NOT_HANDLED
VIDEO_TDR_FAILURE - amdkmdag.sys
could you please provide me with some links? I do not understand what the all the numbers are referring to and I would like to not buy the wrong haha
