G
Guest
Guest
Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.homedesigned,alt.comp.hardware.pc-homebuilt (More info?)
Hello all,
Im a new pc builder and have just ran into an enormous problem. First
let me tell you my specs, everything is brand new, except for the
power supply and optical drives:
ANTEC TruePower 480W
ASUS A8N-Deluxe SLI
AMD Athlon 64 3200
WD Raptor 74GB SATA
Maxtor MaxLine III 250 GB SATA
ATI Radeon X700 PCI-express 256MB
Sound Blaster Audigy 2 ZS
Pioneer DVD-107D burner
Creative 52x CD drive
Floppy Drive
3x Corsair 512MB DDR-DIMM ValueSelect
Couple fans
I built this pc, reading all directions really carefully, took me 3-4
hours, cuz I wanted to make sure everything was correct. I double
checked everything. I plug all the correct wires etc....
So now I come to turning on the pc. I first turned on the power
supply... I saw a light turn on in my case, i believe that was my
motherboard, so thats good. I would like to stress that the computer
was NOT IN USE, this was the first time I turned it on. So now to turn
on the pc, i pressed the ON button......
DAMN, the thing i feared most occurred. I heard a pop and saw a flash,
and the pc did not turn on. A real bad odor came out of the power
supply. So Im assuming the power supply burned out....But PLEASE, for
I cannot afford another computer, tell me that hopefully the other
pieces of hardware are fine.....Again, the computer was NOT IN USE,
this was the first turn on.....
Please, your help and suggestions are greatly appreciated.
Thanks
Posted using the http://www.hardwareforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.hardwareforumz.com/Home-Built-HELP-Power-Supply-burned-ftopict58633.html
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.hardwareforumz.com/eform.php?p=296951
Hello all,
ASUS A8N-Deluxe SLI
AMD Athlon 64 3200
WD Raptor 74GB SATA
Floppy Drive
Couple fans
Thanks
