So basically, i am looking to overclock my Gtx 980 properly, i am confused with things i have herd and read, Regarding the +Mv and Power Limit % And Ov Limit according to Msi Afterburner.
I have a 850w Power supply, so i should have extra, however my concern is how do i know if my overclock is starved for power or if my overclock has too much power thats going to waste and if these are causing the crashes? Any help would be awesome! even a link to explain these is fine. I see this OV Limit on msi after burner and the values are either 0 or 1, and ya sometimes its 1 and sometimes its 0. is this important at all? Also while i have my GPU Z up and running their demanding little box thing, it seems my voltage will not go higher then 1.2500 ,
its weird because in some games or apps its like the MV wont activate? i will know this because with it it also boosts the clock abit, and i can check the voltage, where as others it activates and ya....or something like that >.< i dunno its confusing. Help please
But ya its like some applications are not getting the boost to the clock from the MV. even tho they run the gpu at 99%, and others do instantly, and again some games seem to hate overclocking and others thrive on it, like blizzard games crash if i have a high overclock and i dont have the time to figure out which variables it is so i just play with a lower overclock, not that many blizzard games are worth overclocking for with a gtx 980 anyway, but still..it would be nice to have a nice global overclock and then a low overclock and a extreme overclock for benchmarking.
