I need some help recently I bought a PrimoChill PrimoFlex Advanced LRT 3/8in.ID x 1/2in.OD Tubing- Crystal Clear and for some reason my fittings doesn't fit. I have a Phobya 3/8 ID x 1/2 OD fittings. can anyone give some advice why it doesn't fit well and what kind of fittings should I use?
here is the link of what I tubing and fittings I have:
http://www.amazon.com/PrimoChill-PrimoFlex-Advanced-Tubing--Crystal/dp/B00A0PZZYQ/ref=sr_1_4?ie=UTF8&qid=1447808740&sr=8-4&keywords=primochill+3+8+x+1+2
http://www.performance-pcs.com/phobya-13-10mm-10x1-5mm-compression-fitting-outer-thread-1-4-black-nickel.html
